Old 12-29-2008, 12:03 PM   #9 (permalink)
aerohead
hood vent safety mention
I've driven cars old enough that,on occasion, they entertained me with exploding coolant hoses,and radiators.---------------------
Should you do the hood exit,in the event of a cooling system breach,you might find yourself blinded by a windshield covered in glycol and hot vapor attempting to condense on the glass if below it's dew-point.------------------
The mix won't wipe away like rainwater,and if,say you were right in the middle of a lane change in heavy and fast close-quarter freeway traffic,it might all end in a mishap.---------------
This may be a reason why auto makers have "neglected" hood-cited exits.--------------------
If you were to cite the exit closer to the A-Pillars,you'd be dumping air in to very fast-moving,lower static-pressure air than in the centerline,and should the system open up,center vision might be maintained.---------------------------
A kid threw a rock off an overpass in Los Angeles which shattered the windshield of my CRX once.I was in a situation as mentioned above,totally blinded,and it's a miracle that I escaped the situation in one piece.-------------------
Plan for the worst,hope for the best.
