holypaulie, I like the hood mod. Did holes of that size effect the hood's strength? Does it flex under normal use?
I've played around with the a Magnehelic gauge and the aerodynamic flow profile makes sense to me. I found lower pressure 6 inches back from the front edge of the hood, and higher pressure up by the cowl.
I'm going to next check along the side of the front fenders and further off the center line of the hood as suggested by aerohead.
Thanks again for all the input.
