It may be the glow plugs that do not heat enough. Under 8°C mine are switched longer and in this case I switch them 2 to 3 times before starting the engine.
Does your glow plug light is lightening longer than during a hot weather ?
A 10w oil should be enough as it should work for -17°C (0°F).
I have found that high grade diesel make the start easier, but I have only -3 to 3°C (27 to 36°F) temperatures.
My battery is new. May be yours is telling you that it's too tired for such a cold weather.
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving: - 5725.5 kg CO2 (5342.6+382.9)
- Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
