Old 12-30-2008, 12:52 PM   #56 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Easiest way I've ever found to drill/tap plexi (not lexan) is with a heating element.... put the drill bit into a soldering iron, which requires tapping the bit's backside, or using a torch to heat the bit.
Same with tapping - put a screw w/ the same threads onto a heating element, and melt it into the plexi, then back it out when it's set (not squishy). I used to build display shelves as a side job at Sears when it was slow in the shop.
Regardless, Lexan is SOOOO MUCH easier to work with, if not a little expensive. You can usually get scrap from lots of hobby places and craft shops, or look for someone tossing a display case, as many of them aren't big on doing glass cases anymore.
