Old 12-30-2008, 06:13 PM   #11 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by basslover911 View Post
LET ME KNOW!!!
All the Mazda 6 guys claim improved mpg, but for $80 I dont see the return on gas... but If I can make one like you for less than $10 then I will for shure do it...
I have MPFI though
Which just means less work for you. There are 3-4 bolts/nuts/studs/whatever holding the TB on, put a spacer behind it, and you're good to go. You'll need two TB gaskets though.
Subscribed for results - wanna see if "bigger is better" in this case.. If adding more than 1 spacer really does anything more for it.
This would be an easy/great first mod for wifey to try on her car, since she's into engine work anyway and wants to learn to fabricate stuff.
