Originally Posted by Clev
BTW, the Tesla doesn't use hub motors. It uses a single AC drive motor coupled to a fixed 8.28:1 gearbox, so it still has axles.
I thought something like this, so I went and looked at the site again... I didn't get specifics on the gear ratio, but it does use a single motor.
Also, the hub motor idea could be more pheasible when the hub IS the motor. Which has also been done.
The design can be DIY'd by making a magnetic induction motor where the armature is stationary and the "housing" is the mobile part. Add a inner bearing race to each side of the armature, and an outer race to each edge of the "housing", and press them together. Mount a tire on the "housing" and you've got an electrically operated tire, where the center stays stationary (so it can be mounted to a car.) I'm not sure how to cool it or anything else yet though...
Check on back episodes of "Ripley's Believe it or Not" there is a guy that made a 1 wheeled vehicle (it's gas powered) but look where he sits... that's the same idea.
