Old 02-04-2008, 02:35 AM   #52 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
I keep having other stuff to work on or I probably would have had the back end totally finished and ready for the new plastic panels. I figure a few more hours of playing with a plasma cutter will finish up the rear end
The front I will hopefully have an easier time of since it seems pretty simple compared to the back. I probably won't attach two of the engine mounts yet and wait till there is an engine in there to make sure they stay lined up properly.
Check out this patent: http://www.patentstorm.us/patents/6561575-fulltext.html
Code:
he device was formed from PVC pipe having a three-inch diameter, and utilized
an air inlet having a six-inch diameter. After two consecutive calendar quarters,
a second air channeler device of similar construction was employed with the same
tractor unit, in a similar configuration to that shown in FIG. 8. Gas mileage statistics
both with and without the air channeler devices are presented in Table 1 below.
TABLE 1
                Year 1          Year 2          Year 3          Year 4       Year 5
    Quarter Gal @ Mile/Gal  Gal @ Mile/Gal  Gal @ Mile/Gal  Gal @ Mile/Gal  Gal @ Mile/Gal
    1st Qtr.  38,837 @ 5.80   35,329 @ 5.71   38,125 @ 5.15   33,835 @ 5.05  28,588 @ 6.16*
    2nd Qtr.  42,594 @ 5.85   37,296 @ 5.60   37,519 @ 5.65   38,217 @ 5,78  33,068 @ 6.72*
    3rd Qtr.  36,281 @ 5.57   31,694 @ 6.06   29,781 @ 5.77   34,753 @ 5.75
    4th Qtr.  33,752 @ 5.94   36,841 @ 5.95   35,173 @ 6.00   31,600 @ 6.09*
    *Air channeler installed.
Those improvements were on a semi with 1 or 2 3" air ducts installed channeling air from the front with a 6 inch opening to the rear. I plan on making one that is 6-8" high by 2 1/2' wide with an opening as wide as the area between the signal lights so I should see a better gain
