MPGuino problem
I bought a Fundamental Logic V2 MPGUINO kit and assembled as per instructions. I loaded the drivers and uploaded the Arduino sketch as described in the instructions, all appeared to load successfully. The display screen back light is lit but apart from that I get a blank screen. I have repeated the process many times with no success. I assume the bootloader is pre-installed on this kit? if not how can I check? What other checks can I make.
Regards
Terry
