Old 01-04-2009, 11:28 PM   #6 (permalink)
TestDrive
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
If the fuel in your tank is the same temperature as the fuel you're pumping into the tank (a huge - almost certainly unwarranted assumption) - and you know that temperature (it probably isn't air temperature, then you can use the chart CobraBall provided to make a calculation.
I certainly can't speak for everyone here, but I have better things to do with my time than attempt to correct for this factor.
