I was thinking about using LED's with projector lenses for my low-beams... if I could get like 200-300 feet of blue-ish/white light (below 6000k, probably closer to 5200k, easier to make out shadows at distance) that would be sufficient for a headlight for me.
I think the biggest obstacle would be proper aiming of the beam that would be created by a projector housing vs an open beam housing, and whether to use an actual projector crystal or just make a piece that is concave on the light side and convex on the emission side.
The problem with this is that projector lights don't seem to have very good side views, due to the beam density created by the lens. Maybe a different idea is in order, for that reason alone.
