Old 01-06-2009, 11:26 AM   #1 (permalink)
Cepheuz
Mr. Jones - '02 Skoda Fabia Classic
90 day: 19.09 mpg (US)
Send a message via MSN to Cepheuz
Lean burn for carburetor engines (posibly fuel injected too)
if you achieve your target speed and load, i think leaning the mix would be benefitial
can a person simply make a meter devices to inject air into the manifold, possibly trough the brake servo vacuum line?
tap into the ignition vacuum advance, the fuel enrichment and a plenum vacuum, when the vacuum advance is activated and the enrichment is not open the vacuum to the plenum and it will enrich the mix
then you would have a normal lean mix that doesn't hinder acceleration or load and you can adjust the lean mix even further by metering the leak amount
it's just right now an idea, but i think a plausible one
