Old 01-06-2009, 05:22 PM   #10 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
The new one looks much nicer mounted and stuff.
So the dash on my Astro is pretty well complete now. The gauges on the side are a tach and air bag control. The led that is pulled out of the dash is the torque converter lockup indicator and the mpguino sits in a box right below the temp gauge. I just need to glue something down so the box snaps in place instead of being held on with double sided tape.
Once I figure out why I am not getting a vss signal to the computer and fix that then it is setup and working again. Right now I can only use it as a gallons per hour display. Hopefully the vss controller in the ecm isn't burned out so it will be a minor fix to get it going.
Name:	100_0520 (Small).jpg
