Old 01-07-2009, 01:29 AM   #131 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Originally Posted by Christ View Post
So if at 120v 20A the motor spins 500RPM and creates 50lbft TQ, and I switch to 240V 10A, It will create the same 50lbft, but at 1000RPM?
I don't think it works that way. I've been thinking about this all day! It has given me a headache, and here's what I think I know:
The Torque-RPM curve is approximately a straight line for a DC motor. At 0 rpm, the torque is highest, and at max rpm, the torque is 0.
At 240v, the MAX rpm is 2 times the MAX rpm at 120v. Also, at 20 amps, the MAX torque is 2 times the MAX torque at 10 amps. So, I attached a picture of the graph of the torque-rpm lines for 120v @ 20amps and 240v @ 10amps.
In the picture, w120 is the max rpm at 120 volts, and T10 is the torque at 10 amps (2*T10 is the MAX torque at 20 amps and 2*w120 is the MAX rpm at 240 volts). Their rate of rotation and torque are the same at one point, when the RPM is 2/3 of w120 (algebra! Find where 2 lines cross! hahaha!)
There are some torques that the higher voltage setting just can't match, and some speeds the higher current setting can't match.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
faerietree (07-14-2012)
