Well hello everybody, and Happy New (EM) Year!
I was thinking about water injection as a means to cure my 07 Civic's lackluster response in hot weather (a whole other story), when I contemplated means to improve gas mileage under light loads.
Can anybody think of any reason why dropping some cubes of dry ice (frozen CO2, no?) into the intake would not trick the ECU to interpret that as a low oxygen environment and reduce the fuel injection rate? My theory is that the dry ice when returning into gaseous CO2 would mix with the air rushing past it. The air/CO2 mix should have less oxygen in it and to keep the fuel/air mix right, the engine would have to reduce the amount of fuel injected, therefore causing a lean burn, right?
Think: Nitrous injection - but the opposite!
Maybe it would choke out the engine completely? Could this hurt the engine? Thanks for the feedback!
