Old 01-09-2009, 12:18 PM   #52 (permalink)
instarx
EcoModding Dilatant
Volvo - '00 Volvo V70 XC AWD SE
90 day: 27.7 mpg (US)
Originally Posted by Christ View Post
Secondly, the engine does not SEE the inertia required to spin the non-drive tires.. it only sees them as dead weight. The fact that they roll means nothing.
I disagree. There is no free lunch. Non-driven wheels are not easier to turn than driven wheels. The non-driven wheels are being rotationally accelerated at the same rate as the driven wheels. It makes no difference whether the wheels are accelerated by a drive shaft or from being pulled along the ground - it takes exactly the same amount of energy to accelerate each wheel to the same speed.
A thought experiment: After accelerating a car, immediately lift it off the ground - the non-driven wheels will still be spinning. So where did the energy come from to spin those wheels if, as you say, it took no energy to spin them? How did they get spun? You could generate some electricity or accelerate a flywheel with them. That my friend, would be a perpetual motion machine - energy from nothing.
