That's a good idea Ben. The only thing I'm trying to avoid is the "hair trigger": Getting max torque at like 5% full throttle (near 0 rpm is when this bad combination happens). But If a person wanted 100% of available torque at near 0 rpm (like climbing a steep hill) it should be available, but it should be required that you push down the throttle 100%. The program needs to be changed! Thank you Ben! I'm going to revise it.
