If going with the first design, it will look more like the fast back montecarlo's of the 90's.
Anyhow, you can make it as a three piece spoiler. The side pieces, made of metal or plastic and attached directly to the rear quarter panel and roof. The middle piece made of plexi glass and attached to the roof and the side pieces. Wouldn't look to bad and if you hinged the mounting point at the roof and attached it to the trunk with a single pillar at the edge of the trunk, you could still open you trunk and use it. All you would need to add are some pieces of velcro to keep it attached to the side pieces while driving.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
