Originally Posted by Big Dave
I'm with Metro. I've never seen lower RPM cause reduced MPG. Claims that higher RPM gives more MPG are never substantiated,
I substantiate the opposite premise (that lower RPM promotes better MPG) every day.
Me too. Only exception is if you gear to such a low rpm that you cannot keep going in a lot of your typical driving situations without downshifting, then youll lose mpg.
