Old 01-14-2009, 03:43 PM   #197 (permalink)
MazdaMatt
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
Also... i checked your first post link to the MOSFETS... Ten IRFB4110 mosfets... the datasheet claims 180A continuous? wha?
Anyway, the reason i was looking them up was because i found these guys:
IRC640-ND
they have current sense leads coming off of them. Those micro controllers usually have lots of ADC inputs, so the current sense leads could be attached to those. They could be used for single-mosfet-failure sensing, too. Are these powerful enough? (again, i don't know much about mosfets as compared to other electronics).
So you push the pedal and the ADC reads 0.2v, it then ramps up the pwm until the mosfet feedback reads 0.2v (it is a current output, so use the appropriate resistor to match the throttle) and then it stays steady. When the throttle goes up to 2v, it ramps up the current to match it. This is totally RPM-independant.
