Old 02-05-2008, 11:00 AM   #4 (permalink)
8307c4
beamer - '91 bmw 318is
90 day: 32 mpg (US)
Originally Posted by elhigh View Post
I've been in the facility maintenance gig for a while now, and I can tell you this: on and off kills the bulb. Incandescent or fluorescent, the cycling will destroy it faster. There's no way around it.
No doubt about that but I'm also a firm believer that it is the heat that actually kills a bulb, this I speak from experience as I have noticed time and again the lower the bulb's wattage the longer it lasts.
It's not even the heat per se, maybe a little, but it's the cooling off and warming up that causes expansion and contraction in the materials of the bulb that does it.
So not only does a lower wattage bulb save energy, it also lasts longer.
With CFL's it's the same thing thou with a CFL's actual usage it makes little sense to flicker them, once on leave it on for a bit and don't turn it on for no good reason.
btw all households should be lighted 100% with cfl's by now.
