Old 01-15-2009, 02:08 PM   #21 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
10 Print "Super Single Tires"
20 if tooNew | print "there's your answer"
30 Run
God - I hated BasicA..
Anyway, it's basically just like the reason we can't put a radiator under the body - it's too far from the "norm" basically. Also, lots of truckers still have their current re-treads on, and won't take them off until they won't pass DOT.
Add to that, that even though the super singles use 25% less rubber, they're more expensive to produce, and the common thought that wider tires suck in water/rain/everything else (not counting the 80k lbs on top of them). Plus, they're actually not suited for use with all circumstances, due to their width.
Oh - I don't think you can get re-treads on them either... I think it's "new or not".
