Old 01-17-2009, 12:22 PM   #238 (permalink)
tech2
tech2's Avatar
Another random thought:
If you used ten 12 volt batteries to run the car(or twenty 6 volt) , you should not need much in the way of a battery charger for the thing, just a full wave rectifier circuit, with some isolation and regulation on the output side??
I always did want to play around with this stuff, now I have a chance to do so
