A lot of guys in the pickup truck community have tried larger diameter tires and the empirical result is always the same: Larger diameter tires result in lower MPG.
Wheel and tires are "flywheels" that have to be accelerated everytime you pull away from a stop. The energy stored can be tapped to a limited extent by a skilled hypermiler, but mostly gets wasted.
Forget the tires and get taller gears.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
