Old 01-19-2009, 06:14 PM   #4 (permalink)
aerohead
template
pawilkes,if you do a search for MetroMPG's permanent Kammback,we've got a template you can use.It's developed from a 2.5:1 teardrop body of revolution,which has the lowest profile drag and lowest skin friction.---------- Wing profiles are going to have more skin friction do to their length.-------- If you follow the scaling protocol on our template,you'll end up with a roofline with zero separated flow,maximum static regain,and minimum skin friction,for minimum drag.
