Old 01-20-2009, 03:19 AM   #10 (permalink)
The Atomic Ass
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.64 mpg (US)
Originally Posted by RH77 View Post
On nearly all brand new cars I've tested, the torque converter will engage when the coolant temp is literally 10F and sometimes below! What gives? I have to have 190F+ and IATs in the 90's for that to happen. Argh.
I had a '90 Pontiac Subird, where-in the controller for the TC went bad, and once it locked up, it would not unlock until the car cooled down. I ended up cutting the wire to the controller and just using a switch to operate the TC manually. May be worth it to consider that if your TC is a simple one that operates from 12V.
As for my grill block, I have my radiator 100% blocked. Doesn't cause an issue until the temps rise above 40F. But then my engine is out in the wind, getting air cooled. I don't worry about it going over temp, my gauge has been tested to being fairly accurate, and it hits the red at about 260F. Last winter I was forced into using the highway for a short period during a not-so-cold day, and I was in the red for the last mile before getting off to surface streets. Engine is still running fine, though. So I don't worry if I get between normal and the red, as it usually starts warming my intake at that point.
