Old 01-20-2009, 06:13 AM   #1 (permalink)
modmonster
Tracy - '00 vauxhall corsa
lean burn: now i have a 1k pot on my MAF sensor
through trial and error i have found that about a 0.1-0.2 volt subtraction from the MAF sensor signal leans out the engine nicly.
i noticed that when my MAF sensor broke (lost calibration by 0.5v) i was actually getting slightly better milage on short trips than when i replaced it. altough milage (and power!) was slightly worse on highway journeys -i assume that was because it was too lean.
i've just put a 1k pot on my MAF sensor and i should see higher mpg numbers soon. noticed engine warm up takes much longer because the mixture is not rich.
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
