Old 01-21-2009, 12:00 AM   #24 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Regarding Lazarus' post on the larger tire having less difference in distance per PSI level:
The larger tire has significantly stiffer sidewall area, which reduces rolling resistance. Obviously it's 40-60mm wider (manufacturer's measurements vary), but that may not win-over the loss of friction and warpage associated with tall/thin sidewalls.
