Old 01-21-2009, 08:30 PM   #274 (permalink)
rgathright
Black Beauty - '09 Honda Accord EX-L
90 day: 27.44 mpg (US)
Originally Posted by MPaulHolmes View Post
He is running his controller with current and temperature limiting, etc... with the parts I listed. He has a worst case scenario motor setup for a controller. It's an 11 inch WarP (I think) with no transmission (direct drive!). He blew up a 144v 500amp Curtis, so built his own to handle it. It also uses Lithium Iron Phosphate batteries I think.
Direct drive! Yes!
The motor's are great because they can operate above 11,000 RPM. Which means your motor requires little power to rebuild its EM field above 5,000RPM after a restart (acceleration). A direct drive motor is also very easy to install in trucks because you can use the bed to hold the batteries and controll/charging equipment with the motor beneath. With all equipment on hand and good instructions you could convert a Dodge Dakota pickup over the course of two weekend with two people.
