actually...this wouldn't be the most efficient way to do this, but if you have a manual transmission...couldn't you really just have an on off switch and flick it when you need power and use the clutch like a gas pedal? I don't know if that would actually work, but I was just brain storming after reading Ryland's post about electromagnets pulling simple switches closed...
