Old 01-23-2009, 11:37 AM   #2 (permalink)
Daox
Originally Posted by RobertSmalls View Post
Most annoying is the very high idle until it warms up.
Get a block heater!
Can I force it into closed loop idle?
There's a seperate issue: whenever I open my throttle more than, say, 1/3, it goes into open loop. Yeah, I know, welcome to the real world. Still, can I keep closed loop for slightly larger throttle aperatures? What if I mod the TPS?
Even if you're able to, you do not want to. The engine is running as it should.
