Old 01-23-2009, 02:30 PM   #20 (permalink)
Frank Lee
OK, I'll work on this one a lil bit myself.
Originally Posted by bikin' Ed View Post
ddanz, I don't understand why you want to make the neon RWD, except that you want it to be different.
cuz when you pull the fwd eng and tranny out what are you left with? a couple shafts whose inner ends are floating in mid air. bolting motor onto live rear axle = simple in comparison
FWD is by nature more efficient than RWD due to rolling friction losses.
I can't identify any reason why this would be so. In fact, in the case of my Tempos, it may be worse just for the reason that it has 4 wheel independent suspension, which I'd imagine wouldn't maintain as good alignment control as a vehicle with a live axle.
However, if you must, I'd suggest a donor car. Cut out the front suspension and subframe and graft it into the back.
then he still has the lack of anything to hook the cv shafts to; and now he also has to fix the steering straight ahead. and, find a home for struts if it doesn't already have them, or if they aren't compatible. this sounds like the most complicated way of all!
My other thought on your project is to keep the FWD, and modify the trunk for installation of your generator. When it's all closed up it will look totally stock--the ultimate sleeper.
keep the fwd how specifically? using the tranny, using only the diff part of the tranny, making a homemade or adapted diff... what?
