Old 01-23-2009, 06:44 PM   #20 (permalink)
ZachUA
Beefy
Daox, I'm reading the site you recommended, great stuff!!
Esonson, I hadn't asked yet bc I thought it might come across as me questioning his truthfulness. He is also giving me a good deal on the rent (charging me less than the previous tenant) and not charging me any other utilities so I wasn't going to push the issue.
bennelson, the meter looks to be separate to me, but I will take a pic soon and show what it looks like. Basically there is a regular meter, (the one with the little spinning disc inside), and then splitting off that is a much smaller square box with some digital numbers on it. I was told the smaller box with numbers is the readout of my apartment and the big one with disc is his. There is a garage but it isn't heated.
trikk, I can tell you that he told me the previous occupants bill averaged around 125.00 up to 150.00. That was a couple and the man worked and the woman stayed at home a lot. I'm sure they had the AC/Heat running all the time if there was always someone home.
