Old 01-24-2009, 11:45 AM   #7 (permalink)
Snorg
Dracola
Snorg's Avatar
Originally Posted by basslover911 View Post
But what if you injected the water as a vapor already? Heat the water to around 300 degrees and inject it... what would happen? Would it heat the engine up to much? Could you still advance timing?
What would happen is you would just pump the crankcase full of water.
