Old 01-24-2009, 03:43 PM   #15 (permalink)
aerohead
viscosity
On the surface it all sounds great.There is no mention of laboratory conditions nor road test environmental conditions,like temperature.Since viscosity is directly related to temperature,fuel temperature criteria would be beneficial to better appraising the research results.----------Had road -testing been accomplished during winter-into-spring-and summer,ambient temperatures, the impact to results would be remarkable.Perhaps all the data has been normalized for that.Don't know.-------- I believe that fuel is paramagnetic,so a magnetic field should not effect it,however,the presence of a high voltage potential( ie the high-voltage mesh grid) could certainly affect the fuel if even for for the short duration necessary before it makes it to the injectors.-------- Sounds plausible.
