Originally Posted by Ryland
An electric heater heats up faster then the gas engine can heat the coolant allowing you to drive within seconds of starting the car...
I drive within one or two seconds of starting the car without block heaters or anything of the sort. The best way to warm the engine is under load, not idling.
