Im trying to repiar a Powerflex 70 rated at 50 hp to test that. the only concern i have is variable acceleration rates, like when pulling out in faster moving trafic. its vary possable.it has alot of the same parts as a ac car controller but with diffrent programing. I cant believe no one has done this before. it may work out of the box but may need some programing. also im sure that auto ac controllers have more safety features, so if i do it i would have a way of disconnecting the power in case of a failure. like how on what was that? i think it was project forkenswift he used the old clutch to seperate the battery pack from the controller using those heavy duty fork lift plugs.
