Old 01-25-2009, 01:59 PM   #17 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
There are far more accurate and direct ways to test the viscosity of a fluid than measuring its flow through an injector or putting it in a vehicle and measuring fuel efficiency. If gas or diesel is an Electrorheological fluid why not test it using a direct and accurate method?
Probably because the data won't show an improvement and its easier to manipulate the results if there are far more variables that can't all be accounted for.
