Old 01-25-2009, 05:08 PM   #6 (permalink)
Snorg
Dracola
Snorg's Avatar
Ok Bob
Originally Posted by Bicycle Bob View Post
A nominal 120 V battery is usually made from 10 nominal 12 V batteries; they are only over 13 V when fresh charged.
Ok Bob, but with 10 batteries will the onboard 120V generator be able to fully charge them ?? If they only get charged to 12V each is that good enough??
For brakes, you will need regular friction brakes to stop much harder than you can accelerate. Regenerative braking will extend your range a bit if you can use it downhill or for gentle stops.
OK Bob, regenerative braking would be very good here in this hilly country.
If I buy a 120V motor made for EVs and a proper controller will the controller provide regenerative braking??
Im in BC can you give me web links to where I could by the motor and controller??
thanks Eh?
