Old 01-27-2009, 01:02 PM   #27 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
I haven't with this motor, I did with an older Cavalier Z24 engine (non-stock 2.8 hybrid) but we were using a butt dyno and just adding tubing to see where we could get a decent bump.
IIRC, we ended up using that 17 inches of piping, which, given the limited space, ended up being more restrictive at mid-high RPM b/c of the number of complex curves that were necessary.
I haven't looked into it any further, we only did that as an experiment for a school report when I was in 7th Grade.
I've thought about a few ways to make an intake manifold that will constantly adjust it's runner length based on RPM, but nothing has come to fruition yet. I believe that technology is something better served for use with engines that have truly variable valve trains, run by solenoids and a computer, with no cam. Said engines will probably also have variable compression and stroke characteristics... and it won't be me that invents them. I'm not that smart.
