Originally Posted by Christ
You can add propane to your gas engine relatively easily if you want to use less gasoline per combustion cycle, but in order to lower the actual size of your engine, you should just REALLY lower the size of the engine, instead of trying to add stuff to your mixture.
There's EGR. I would believe injecting steam is pretty much just like injecting an other inert gas.
