Old 01-28-2009, 12:41 PM   #33 (permalink)
MechEngVT
Mechanical Engineer
The Truck - '02 Dodge Ram 1500 SLT Sport
90 day: 13.32 mpg (US)
The Van 2 - '06 Honda Odyssey EX
90 day: 20.56 mpg (US)
GoKart - '14 Hyundai Elantra GT base 6MT
90 day: 30.31 mpg (US)
Godzilla - '21 Ford F350 XL
90 day: 8.69 mpg (US)
Originally Posted by wwest40 View Post
Look at it this way...
Using the current implementation of the Atkinson cycle, delayed intake valve closing and 13:1 "native" compression ratio, look at what would happen with just a single cyclinder engine. You would have reverse airflow OUT the intake path/duct for each compression stroke, not exactly viable for a MAF/IAT equipped engine.
I meant to address this in my reply yesterday since IIRC it came up earlier in the thread...but I think christ answers correctly.
This WOULD cause a problem with either an incorrectly designed intake or if you had a single throttle plate per cylinder with no "manifold" per se. In the first situation a proper chamber volume or resonator would buffer the pressure pulses and allow a continuous inflow through the throttle (and therefore the MAF sensor) the way that normal intakes already do this to a lesser degree. In the second situation (one butterfly/cylinder with no resonator) you don't even need a MAF sensor and can map fuel/spark from TPS and RPM.
