Old 01-28-2009, 05:19 PM   #316 (permalink)
Oval_Overload
24.27 lbs per gallon Co2
Oval_Overload's Avatar
Unicorn - '12 Nissan Versa 1.8S hatch
90 day: 31.9 mpg (US)
Originally Posted by rgathright View Post
Your idea does work in PC applications, however when mounted in a car the vessel that holds the mineral oil must be built to handle the stresses of frequent bumps and tips.
Also, finding the right vessel to contain the fluid would be tricky because it could not be a conductive material either.
What about a watertight electrical enclosure? They can usually be found in plastic.
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
