Old 01-28-2009, 11:12 PM   #35 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
You probably should use longer bolts if you plan on making more than 1mm of spacer. The typical flange is only 1/4 of engagement, and most OEM's use the "correct" length bolt for many things these days.
Also - you should have studs... most do, iirc.
