Originally Posted by bennelson
So 4x4s have bigger tires to get them up in the air to make room for all the front wheel drive stuff, and then lower gearing to match the speeds back up to where they should be?
No 4x4 r up more cause they are designed to be taken off road And need the clearence
Best set up may be to remove the rear driveshaft and mount a e-motor to it. It would allow more room. And just run the truck in 4 hi so the front drive shaft will power the front wheels with the motor
