Old 01-30-2009, 06:28 PM   #1 (permalink)
wwest40
Ebable sub-freezing regen...
Ford has a US patent that decribes a technique wherein the regenerative braking is substantially reduced if the OAT declines to freezing and below. The patent also defines a technique wherein should impending wheel lockup be detected by the ABS system during actual braking regen will be INSTANTLY disabled.
Anyone tried defeating the regen reduction via an OAT sensor modification..??
