Originally Posted by MPaulHolmes
Fran Sabolich on the EVTech list has helped me with this subject. He drew up a schematic as well which I plan on using in the final draft.
Fran's Schematic
I've moded it slitely
I'll check out your schematic as well. Thank you!!!
In my circuit mosfet itself is current sensor. And then hoter mosfet is, then higer Rds-on and then lower protection treshold is.
IR2127 starts masurament after 750 nS after gate ON and if voltage from "D" throw resistors network is higer then CS treshold voltage - IR2127 turns off mosfet and FAULT pin is LOW (for MCU inform) FAULT will be osolute after "IN" lowering by control sirc.
www.irf.com/technical-info/appnotes/an-1014.pdf
IR2127 can work like low side driver too.
Spaceeba! Voui Harasho gavaritia pa angliski!
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
Russia, Moscow.
