Old 02-01-2009, 01:55 PM   #4 (permalink)
Vwbeamer
Ruint Taco - '19 Toyota Tacoma SR Double Cab
90 day: 23.76 mpg (US)
I think you are thinking of engines with no cam on the intake. Cylinder vacuum opens the intake and cylinder pressure closes it.
There are engines with no springs, cams open and close the valves. Ducatti is famous for there valves without a valve spring proper.
Ducati Desmo Valves
Originally Posted by Bicycle Bob View Post
On old, very low-speed engines, you may find no valve springs at all. Air opens and closes the valve. The main job of the valve springs is to avoid "float" -they overcome the inertia of the valve and lifter and keep them in contact with the cam as they start to close. That force goes up as the square of speed, so it pays to avoid high revs. If you are going to lower the red-line, a cam with less dwell and overlap is better, as there is less inertia in the manifold gasses.
The Following User Says Thank You to Vwbeamer For This Useful Post:
MobilOne (11-23-2015)
