Hi,
There is a cam-driven engine that is 39.5% efficient:
Revetec Development
The two cams rotate and raise the piston with a scissor-like action to the bearings. Once at the top of the stroke the air/fuel mixture is fired. The expanded gas then forces the bearings down the ramps of the cams spreading them apart ending the stroke. The point of maximum mechanical advantage or transfer is around 20-30deg ATDC (the piston moving approximately 10% of its travel) making the most of the high cylinder pressure. This compares to a conventional engine that reaches maximum mechanical advantage around 60-70deg ATDC. (after the piston has moved through just over 40% of its travel, losing valuable cylinder pressure).
