Old 02-07-2008, 12:05 AM   #7 (permalink)
WaxyChicken
Nomadic Chicken
WaxyChicken's Avatar
Originally Posted by RH77 View Post
Yikes -- I had a '77 Olds that I put that stop-leak purple stuff in all the time. It still leaked and got stuck between shifts when cold. Had to sell it for that reason.
Have you tried the stop-leak product? Which car, BTW?
RH77
My SkuttleButt. (96 Ford Taurus) I could call it "S**tButt" because all that
transmission fluid ends up on the rear bumper and the sides of the car as it's
driving and leaking. So all the fluid i put in eventually winds up dried out on
the butt of the car.
The stop leak didn't work, i only tried 2 doses of the stuff (i don't want TOO
MUCH clotting in my transmission) The problem is a (cracked?) transmission
line where a nut joins it to the (engine? transmission? don't remember for sure
where it's joined.)
I tried to tighten it with a wrench to see if maybe it was just loose, but no
luck. it's on stiff and there is almost no room for a wrench.
BTW, it's been leaking this way for about 2 years. ($6 a gallon of transmission, you do the math) I'll be glad when i get my EV done.
