Balsa or plywood framing? Hemp fibre and corn resins for panels? Alloy subframe with polystyrene hand carved shell?
Some design principles could be sooo easy like pressing an alloy sheet into a big 1 piece skirt that is essentially the whole body shell, on top a little jetsons clear bubble, hinged on one side that flips open to get in and out off. 2 piece's period! over an alloy subframe with a ply and carpet lined cockpit, that seals against the bubble.
